Redeem echo dot gift
andy starrs
Message 4 of 4
They have sent gift code how do I retrieve gift
3 REPLIES 3
Arne-TalkTalk
Message 1 of 4
Hi andy starrs
Use link https://www.amazon.co.uk/dp/B08K8B6F99/ref=as_ext_tt_aucc_bn
Add the code when you are on the checkout.
Hope that helps.
Tarragon
Message 2 of 4
Andy,  Please let me know the resolution to this as I expect to have to go through the same hoops to get mine!
fre55die
Message 3 of 4
Hi @andy starrs
VERY IMPORTANT FOR SUPPORT !!!!!!
Could you please ensure that your personal information is up to date in your profile INCLUDING your registered landline number
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info.
This is purely so that the staff can tie up your details and trace your account as this is not possible from just your screen name.
Thank you
