Reduced screen size and no volume
des09
Problem Solver
Message 8 of 8
I'm getting a reduced screen size on terrestrial TV (letter box) Plus no sound. All stations the same. No problems at all on internet connected sites.
Cliddy
7 REPLIES 7
Message 1 of 8
@des09
I'm pleased that all is now working.
Message 2 of 8
Not sure I sorted it out, something happened overnight. Anyway all good thanks.
Cliddy
des09
Problem Solver
Message 3 of 8
Thanks for response. Yes I Checked all that yesterday, all secure.
But see above for the conclusion, all good now. Many thanks Dave
Cliddy
Message 4 of 8
Glad you sorted this out.
des09
Problem Solver
Message 5 of 8
Many thanks for getting back.
Just for completness, I discovered the problem yesterday evening. I checked cables, fully reloaded etc etc.
No luck. Within settings I manually manipulated the screen to full size.
Probably not perfectly, but looked ok. But obviously sound still off.
This morning, all is good !! Picture size perfect and sound restored.
Don't know how, but saved a day of puzzling.
Thanks for getting back quickly though. Cheers Dave
Cliddy
Message 6 of 8
How are you getting on? Do you still need assistance with this?
fre55die
Message 7 of 8
Hi @des09
Have you checked the HDMI leads are properly lodged? The last time that I had this, I turned off everything at the mains, swapped the leads over so that connector in TV went into box and vice versa, gave them a quick wobble to make sure that they were properly seated, then restarted everything. It all was restored.
