Remote Control slow or not responsive
mrwrighty
Whizz Kid
Message 1 of 10
My TV box remote has become slow to respond and some buttons required a long hard press to make them work. I have the original marked J124403 in the battery compartment which I've had since we originally took TalkTalk TV. Can I get a replacement.
9 REPLIES 9
Message 2 of 10
Have you tried a reset of the remote control:-
https://community.talktalk.co.uk/t5/Articles/Remote-control-troubleshooting/ta-p/2204449
Message 3 of 10
Thanks for your help, but as mentioned in my comment, the remote works but some buttons taken a long hard press to make them work. This is normally and indication that the circuit board is breakng down and can also be the result of the failure of the button contacts which means they require longer presses to respond. The remote is sync'd correctly and doesnt have issues controlling the TV or the TV Box other than the delayed rsponse. The remote batteries have recently been replaced. The handset is probably 5 or more years old.
Message 4 of 10
I will ask one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Message 5 of 10
Hi mrwrighty
I'll get a remote out to you and you can retest.
Message 6 of 10
Thanks OCE_Karl.
Message 7 of 10
No Problem 🙂
Message 8 of 10
New remote arrived thanks. All good with the TalkTalk TV box however the volume is very sluggish controlling the TV.
I can’t find any instructions for the V4 remote only v1,2 and 3. I’ve followed V3 instructions and held the search button until the LED flashes and goes steady and used button 8 for my Sony Bravia. But when changing the volume it takes a couple of presses of the volume button to get the volume on the TV to respond.
I also saw instructions about using OK and the top right power button to get to the TV settings mode but couldn’t get that to work.
Message 9 of 10
We do try to keep our help site up to date with as many manufacturer codes as possible, and newer codes are added as they are provided from the various manufacturers.
You can try searching for a generic code that may work, by using the search function on the remote, and more advice may be found within our Online Help Article.
Message 10 of 10
Am I using the correct buttons to set up the TV, i.e. pressing and holding the search button until the LED flashes.
