Remote not sync with tv- only 1 button not working
Butterfly211
Message 6 of 6
Hello
have now received a brand new tv box and still the remote doesn’t switch on and off the tv
i tried a different remote o had and same issue
i reset the remotes a few times (press 16 and then 981) but still nothing
everythg else works, just not the on and off for the tv
thanks
5 REPLIES 5
Message 1 of 6
I can only suggest you try a google search for any better codes.  We have the ones supplied by manufacturers on our help section but not all models are included.
Message 2 of 6
can you advise what other codes I should try?
I followed instructions from talk talk, so let me know
Message 3 of 6
if 2 remotes fail to operate the TV on / off function, there may be an issue with the code you have entered when setting up the remote. We can only suggest you try another code.
Message 4 of 6
All works with the except of the on- off to the tv
Message 5 of 6
HI
Do the remotes operate all functions of the box?
