Roku Streaming Stick
Stan1962
Message 7 of 7
We have been with TalkTalk for a few months and everything is good apart from our Roku which has stopped working. All the channels come on but the remote control does nothing. We bought a new remote from e bay but that does nothing and it does not have the button to re programme the remote.  We have TalkTalk broadband with the F-Secure virus software. We are not sure if this has blocked the signal getting to the Roku. Any ideas?
6 REPLIES 6
Message 1 of 7
That's good customer service from Roku.
GondolaVolunteer 2017-2022
  Like (below) to support me . . . Mark as solved (below)  Accept as Solution
Message 2 of 7
Sorted now. Roku sent us a brand new Roku Express for nothing.
Message 3 of 7
Hi @Stan1962
So you saw the remote control pairing dialogue on the TV screen, yes?
And if so, use the Roku remote to check your Internet connection via the TalkTalk router. Go to Settings > Network > Check connection
Message 4 of 7
There are basically two types of remote control for Roku, a standard IR remote designed for the basic box units and an enhanced "point anywhere" type which connects by wireless. This latter type is required for the streaming stick and has a pairing button on the back. If you don't have the button, then you have the wrong type of remote.
Message 5 of 7
We done all that
Gondola
Message 6 of 7
Hi @Stan1962
Here's the advice for remote troubleshooting.
Check the batteries and go through the process for pairing the remote to the Roku.
