STB Box is very slow
AudreyWadsworth
Message 3 of 3
My set top box DN370t is incredibly slow, is there a newer version or something else I can do to improve it’s speed. The remote control is also often unresponsive
Message 1 of 3
Hi AudreyWadsworth
Try the advice from fre55die and let me know if this helps.
fre55die
Message 2 of 3
Hi @AudreyWadsworth
You could try a factory reset from the main settings menu. Blue YV/Menu button on remote > Up to Settings(cog wheel) > Factory Reset (bottom right).
VERY IMPORTANT FOR SUPPORT !!!!!!
Could you please ensure that your personal information is up to date in your profile INCLUDING your registered landline number
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info.
This is purely so that the OCE's can tie up your details and trace your account as this is not possible from just your screen name.
Thank you
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
