Set top box not working
Paulst73
Message 3 of 3
My set top box keeps switching itself off and at times will not come back on again for a while. It makes a click noise and closes down.
i have tried unplugging etc but it still only works periodically.
Please can you send out a replacement box.
Thank you.
Message 1 of 3
Hi Paulst73
Try the reset advice above and let me know if this helps.
Message 2 of 3
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
