Settup TV box keeps going blank, freezing
limbophonic
Whizz Kid
Message 2 of 2
Over the past 3 days my talktalk TV box goes blank on about 5 occasions, no picture no sound when changing channels, if I return to previous channel that is also blank, I have done a reboot after each issue, remove power, then power back up, also did a channel retune, the last time was Sunday evening, but this time I changed channels it stayed on the same channel, so yet another reboot!
Time for another TV box, I've had this one a number of years, model Dn372t.01.02.p
1 REPLY 1
Message 1 of 2
Try a Youview Maintenance Reset  and see if that helps. Failing that try a full factory reset from the settings menu.
