Sky Arts
Jtreslove
Message 4 of 4
Sky Arts, channel 11, has disappeared from my talk talk tv package, has it been you removed from the package? I’ve retuned my box and it’s still not available. Please let me know why this has happened.
Thanks,
Jessica
3 REPLIES 3
Message 1 of 4
Hi @Jtreslove
Try a retune of the channels and see if this helps get the channel back.
fre55die
Message 2 of 4
Hi @Jtreslove
As @Birchcroft says it is now a freeview (non HD) channel (11) so anyone can watch it subscription free. Any recordings that you have previously made from the "boost" will, unfortunately be no longer be available to watch unless you record them again from the Freeview channel.
Birchcroft
Message 3 of 4
Sky arts is available on Freeview channel 11.  As such it should not depend on the TalkTalk TV package.
