Sky Sports Crickets Highlights on 405
1 REPLY 1
philuttley1
For the past two test matches in S Africa, I've set the hour-long highlights programme to record from, say, 8pm to 9pm. When I watch the recording, the highlights start half way through the recording. To catch the second half of the highlights, I have to record the next programme on the guide (usually Cricket Debate). That recording will start with the second part of the highlights and then the Debate programme will start after 30 minutes. All the broadcasts seem to be running half an hour later than the guide although the guide is in synch with the programmes as listed in the TV magazine we buy. I think this phenomenon applies to all the Sky Sports channels on the YouView box although I haven't tested that thoroughly enough to be sure. Anyone else having this problem?
OCE_Karl
Not seen any other reports.  The recording schedule for each program is triggered by a signal from the broadcaster so not linked to any times that appear in the guide etc.
