Sky Sports freezing
Lizzib58
Message 3 of 3
Happens so frequently we get frustrated and stop watching. Happened today at 13:30 so not a busy time.
I'm on power adaptors.
Message 1 of 3
Hi Lizzib58,
  • Name
  • Telephone number
  • Alternative contact number
fre55die
Message 2 of 3
Hi @Lizzib58
Two things here, firstly you need to unplug your PLA's (powerline plugs) for about 10 mins then try factory resetting them (pin reset) whilst plugged in and re-pairing them. A lot of people don't wait for the 10 mins which fully discharges their memory.
And secondly, if this doesn't work, the following info is needed which only you and the support guys can see and it is ONLY so that they can link your screen name to your account:
Could you please ensure that your personal information is up to date in your profile.
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
