Slow Slow TV box
7 REPLIES 7
Cobra427
For the past year or slow the TV box we have from TT has become extremely slow.  I've done all the reboots, start ups, etc but tono avail.  How do I go about getting anew box?
OCE_Karl
Try a full factory reset from the settings menu.  This will clear the hard drive of any corrupt sectors and then set this back up.
This can often restore the performance of the box.
Cobra427
Thanks Karl, unfortunately I've done all that clearing as read previous forums and possible fixes. whilst it may speed things up by a couple of nano seconds, its still frustratingly slow
OCE_Karl
You have had this box about 8 years, so It could be starting to fail.
I'll get a replacement out to you.
Cobra427
Thanks Karl.  thought it was longer to be honest.  Appreciate this, just hope it speeds things up
OCE_Karl
No Problem 🙂
Cobra427
New box arrived quickly thanks, just for the record though, there was no new remote in the box, fortunately the old remote controls the new box so i won't be returning the remote, just the box and leads.
OCE_Karl
A remote is not sent with a replacement box as the old remote will work across all boxes.
