Sound keeps cutting out
Cookster75
Message 1 of 2
Anyone know how to stop the sound cutting out all the time? Tried restarting the box and nothing.
also my connector kit home light always flashes orange and red never green any ideas?
1 REPLY 1
Message 2 of 2
Try changing the sound output in the settings from stereo to surround etc and see if this changes anything.
If the adapters are blinking orange then this is usually because the communication speed between the adapters is dropping a little.  Check the adapters are direct into wall sockets as extension blocks can cause this.  Alternatively, try other plug sockets if possible.
