Subscription channels not working
Skidtyme
Message 4 of 4
Cant watch any subscription channels....says problem with broadband.. but broadband ok...all HD channels working...recorded programmes etc...have retuned...reset...switched on/off etc...makes no difference
3 REPLIES 3
Message 1 of 4
@Karl-TalkTalk
This is a duplicate you are already sending a new router.
Why do people send duplicates out, it's sooo annoying.
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
Message 2 of 4
The old remote should work fine, but any problems, just let me know.
Mikem
Message 3 of 4
Good morning,
I'm sorry to hear you're having issues watching your subscription channels. I have passed this onto the team to pick up and take a look for you.
Regards, Mike
