Subscription channels unavailable
drdwridav
Message 14 of 14
This is second day in a row I've not been able to access channels (i only subscribe to sky sports), and just when cricket is about to start 😞
I got a subscription channel unavailable message last night. After about 10 minutes it started working again.
Today it has gone again, and no sign of it coming back this time.
I've followed instructions and rebooted box, rebooted router etc etc. No difference.
Please help
David
13 REPLIES 13
Message 1 of 14
Hi Dave,
Whatever the issue, just glad it seems to be working now.
Message 2 of 14
Not totally sure where the issue lay, but combo of replacement box and router has it working again. No problems for last 24 hours so fingers crossed.
I've swapped out the talktalk box and sent the old one back yesterday.
Thanks for all your help Karl
Dave
Message 3 of 14
No Problem 🙂
Message 4 of 14
Cheers Karl,
Much appreciated
Dave
Message 5 of 14
Checked everything this side, no issues showing at all.
Next option is to swap out the TV box to see if it is at fault.
Replacement on the way.
Message 6 of 14
Clear dial tone, all fine at that end. Broadband working fine too (60+ mb download speed) - just the tv issue!
Message 7 of 14
If you check the home phone, can you hear a clear dial tone or any noise or crackles.
Message 8 of 14
Hi Karl
Yest straight in to the box. Tried 3 hours last night turning everrything on and off to watch the golf. No luck! So I've now tried 2 routers, 3 ethernet cables, and even changed the micro filters 😞
Dave
Message 9 of 14
Is the TV box direct to the router with a cable ?
Message 10 of 14
Thanks for the new router Karl. Looks sleek compared to my old one...
...unfortunately it has not made any difference. I've found that which ever router I use if I reboot router and youview box I can get sometimes get it working again, but as soon as it goes into standby (or sometimes just by changing channels) I lose it again and get a subscription channel unavailable, error code IPC6012 message.
Looking through the forum it seems identical to the one being experienced by VickiW? Really frustrating.
David.
Message 11 of 14
OK, the new router should arrive tomorrow and we can see if this helps with the issue.
Message 12 of 14
Thanks Karl,
Much appreciated. It's still the same issue today.
David
Message 13 of 14
Hi David
No issues showing remotely.
I've a replacement router on the way to you to see if this could be failing.
