Syncing remote to tv
Poo123
Message 2 of 2
Can’t sync remote to tv have tried resetting everything
1 REPLY 1
Message 1 of 2
We do try to keep our help site up to date with as many manufacturer codes as possible, and newer codes are added as they are provided from the various manufacturers.
Unfortunately, some models are not listed, and until such times as the manufacturer provides these codes, the help we can offer is limited.
You can try searching for a generic code that may work, by using the search function on the remote, and more advice may be found within our Online Help Article.
