TV Box does not connect to TV
1 REPLY 1
Lesenok
Set up TV box checked that everything is connected; however, TV box information does not appear on TV screen when trying to turn on with remote control. Re-set remote control and tv box but still nothing. TV box channels nor menu appear on TV
OCE_Karl
Check the HDMI Cable is seated correctly.  Don't have two connections - ie Scart and HDMI, just one or the other.  Check the TV is on the correct HDMI channel / source.
Check the box is powered on via the button at the back.
Are there any lights on the front of the box ?
