TV Box not working
HVC73
Message 4 of 4
Hi, my recordable TV box has been switching itself on and off by itself occasionally, now it won't record anything, it looks like it has but when you press play its just a black screen and the timer doesn't change, it also won't record anything when you just press record while something is on.  It also keeps disconnecting from the remote so nothing works and you have to rest the whole system.  I have done a factory reset keeping recordings (some of the older ones still play) and one deleting them all and I still have the same problems.
Thanks H
3 REPLIES 3
Message 1 of 4
No Problem 🙂
Message 2 of 4
Thank you so much for the quick response!
Message 3 of 4
A replacement box is now on the way to you.
