TV Plus Box
gdt214
Message 2 of 2
I have a New TV Plus Box.and am getting bad distorsion on all of my Freeview channels. The Engineer tells me my signal is too strong and I need to purchase an Aerial Signal Reducer. I have done this but it makes no difference. I asked a local TV repair man for advice he told me this:
The problem occurs in our neighbourhood because I live equal distance between two Freeview Transmitters and the new Talk Talk Software is Auto retuning all the time and as a consequence it is distorting my reception.  I have a digital aerial and although it points towards what I consider is my nearest Transmitter the tail of the Aerial picks up the signal from the other transmitter as well. The only way to resolve this problem is to have a box with manual retuning available. Is there another answer to my problem as its driving me mad.
1 REPLY 1
Message 1 of 2
I've seen this issue before, but it is rare,
Unfortunately there is no manual tuning option on the box itself, but you can enable the RF pass through and use the freeview channels via the TV receiver.
