TV Plus Box
Brian65
Message 8 of 8
My TV Plus box is still causing problems and will not now play recordings.  I have carried out factory reset / lose recordings twice in the last four weeks and it seems alright for a couple of weeks although it will freeze when playing back recordings and it has to be switched off and restarted to continue watching.  Last week it excelled itself and now will not play or recordor connect to channel 5 app.   All Creatures Great and Small will have to wait for a while.
Is a new box required?
Brian
7 REPLIES 7
Message 1 of 8
Thank you for your assistance and advice.
Brian
Brian
Message 2 of 8
No Problem 🙂
Brian65
Message 3 of 8
Thanks' for your help and advice Karl.
Brian
Brian
Message 4 of 8
Hi Brian65
A TV Box is on the way.
Gliwmaeden2
Message 5 of 8
The TV Plus box is no longer issued by Talktalk, @Brian65. The monthly £4.00 remains.....!
Brian65
Message 6 of 8
Hi Karl,  if this is the only option then yes please.  Does this mean that the monthly cost of Talktalk reduces or is there a way of getting a new TV Plus box from TalkTalk?  Or have you any suggestions or do you know what others have done?
Brian.
Brian
Message 7 of 8
TalkTalk no longer provide a recording box.
We can issue a TV box however this would be the Lite Box only.
Would you like me to send this ?
