TV Plus box DN372T
Firefly1
Message 10 of 10
I've been having trouble with the above box for more than a week. First it failed to record some programmes and then it failed to respond to any commands, which mean switching off and on at the rear then reloading each evening. Secondly, it failed to play the programmes it did record.
I carried out a soft factory reset but ended up with a blank black/blue screen. I then reset and carried out a hard factory reload, which gave me the same result.
I think therefore a new box is required, but how do I get one?
Firefly1
9 REPLIES 9
Message 1 of 10
Glad the box arrived promptly.
Message 2 of 10
Hi Karl,
Brilliant, new box arrived and I had it set up and running within 24hrs.
Also, please to see that the old box could be returned for recycling.
Firefly1
Message 3 of 10
I'll get a replacement TV Box out to you.
Message 4 of 10
Hi Karl,
I've tried to reload / restart four or five times with little or no success. The TV Box will not work correctly and I think that it is not just a software issue and I therefore have any confidence in it.
For further details please see my email.
Firefly1
Message 5 of 10
Yes, select OK and see if the system starts up.
Message 6 of 10
sorry for the delay.
I have done the factory reset and have now got a 106 error message, with a request to go into Maintenance Mode where I can select recovery mode. Shall I press OK?
Message 7 of 10
Can you go to the settings menu on the youview box and perform a full factory reset for me and then set this back up.  I can then see if there are errors at the box.
Message 8 of 10
Hi Karl
My telephone number has been sent.
Firefly1
Message 9 of 10
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if required. We will then reply via this Community.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you. Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
