TV Plus box problems (DN372T)
kennywilson121
Message 5 of 5
Recently my TV Plus box has experienced regular problems:
  • Increased sluggishness on start up and navigating around
  • Regular failed recordings.
  • Recorded programs cannot be played back - lack screen
This is a new (replacement) box about six months ago.
I have carried out a Software Maintenance  and Factory Reset (Keep Recordings) in the maintenance menu.  It appeared to work briefly after the reset but then reverted to previous issues.  I suspect there is a serious problem with the box itself. Are there any other tests/checks I can try?
4 REPLIES 4
Message 1 of 5
No Problem 🙂
Message 2 of 5
Thanks for your quick response.
Message 3 of 5
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
kennywilson121
Message 4 of 5
I see from other posts that others that have has similar problems with this model of TV box over recent months and the box has been replaced by talktalk.
Can a replacement box be sent out as this seems to be a recurring problem.
