TV Recordings Not Playing
sallyjsmith15
Message 5 of 5
My recordings are either showing as "Failed to Record" or when you go to play them, it goes to a black screen but does not play... I've tried a factory reset (saving my recordings) but it hasn't made a difference.
4 REPLIES 4
Message 1 of 5
A Box is on the way .
Message 2 of 5
Hi Karl,
Looks like I will need a new box, programmes won't play on ITV player or 4OD either...
Thanks,
Sally
sallyjsmith15
Message 3 of 5
Is there any reason for this? It's one of the features I look for when choosing a TV provider. The box works fine other than the recording functions so I don't need a new box if this isn't going to be fixed.
Thanks,
Sally
Message 4 of 5
TalkTalk no longer provide a recording box however we can issue a Lite Box.
Would you like me to send this ?
