TV YouView box turns on but automatically turns off after loading.
Eean1
Message 3 of 3
Hello, wondering about how I would get a replacement youview box, box turns its self on does the ''loading'' screens repeatedly gets all the way to loading and then shuts its self off and we have to repeat over and over again, trying to load settings to factory reset does nothing because the box crashes before it can load anything, replaced the wires, turned the router on and off, dunked it in holy water and the thing still won't turn on.
Tried to use the LiveChat but for some reason it doesn't ''pop up'' and I hate talking to people on the phone because they always try and sell you something, any advice appreciated!
Eean1
Message 1 of 3
That's disappointing, I will just use the normal TV until the contract expires in 3 months and then swap over to someone else and get a new box that way, thanks for your response!
Message 2 of 3
If you have tried factory reset lose recordings, then I'd say your box has had it
Please note that if you are eligible for a new box, TalkTalk now only supply non recordable ones., So it's best to try all alternatives if recording is important to you, so give the factory reset another go.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Please post back when done.
Thank you
