TV/Youview won't change channels, record or play programmes from Guide.
PoppyRossi
Message 6 of 6
My Youview box is no longer working properly - it is only possible to change channels once or twice after a reboot.  It will not record or play programmes from the guide.  I have done all recommended in YV105 and at one point a message flicked up briefly saying there was a technical issue.
I also have satellite TV and that works fine - the remote will change quickly to revert to HDML1 for that to play but on UK TV the remote doesn't change anything.  I have another Youview remote for this TV and have changed batteries but have the same problem.
5 REPLIES 5
Message 1 of 6
Hi Poppy
I'll get the box replaced for you and see if this helps.
PoppyRossi
Message 2 of 6
I apologise - I noticed the message about using original message after I had posted second one.
Message 3 of 6
@PoppyRossi I have escalated to the OCE for them to look into for you.
PoppyRossi
Message 4 of 6
I have done the Maintenance reset as suggested but there is no improvement.  I feel annoyed I am paying for a service I am not receiving.
Message 5 of 6
Have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
Hope it works but if not then please let us know and I’ll flag for further assistance.
