TV box Randomly Freezing and Shutting Down & Apps are Buffering
Vonney
Message 7 of 7
For the last few months my Huawei box keeps going slow, freezing or Shutting down completely. Switching everything on and off again, partial and full resets resolve the issue in the short term, but the issue recurs again sometimes just a few hours later. I’ve also checked that all system updates are up to date. I don’t know what else I can do to fix it?
At the same time I am also experiencing serious problems with buffering when using Apps. This happens even when no other devices are being used and no issues are being reported. I’ve also found that at the same time the Apps are working perfectly well on my iPad.
6 REPLIES 6
Message 1 of 7
I can offer a replacement TV box however TalkTalk no longer provide a recordable box, so this will be the lite box. would you like me to send this ?
Vonney
Message 2 of 7
Hi  @Karl-TalkTalk, I’ve updated my profile with my home phone number now.
Cheers,
Yvonne
Message 3 of 7
Hi Vonney
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
Message 4 of 7
@Vonney
You are in the queue for staff support and they will respond on here but, they will need at least your registered phone number or account number in your profile as requested above in order to identify your account.
Vonney
Message 5 of 7
Hi, @fre55die, yes I have tried that. But like everything else I’ve tried it only resolves the issue in the short term 😞
fre55die
Message 6 of 7
Hi @Vonney
Have you tried a full factory reset from the main menu?
IMPORTANT FOR SUPPORT
Could you please ensure that your personal information is up to date in your profile.
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
