TV box crashes
17 REPLIES 17
Hiltophouse
Super Duper Contributor
My TV box used to have to be hard rebooted every so often (every few weeks/months), that was managable....
Now it seems to have a more major issue.. 😞  it works but after a few hours it crashes again i.e. not responding to most commands. Most the time it crahses the Freeview picutre still works but does not change channel via box or remote. No other menus either.
I've completed Maintenance Mode - Factory Reset but still occurs.
OCE_Karl
Have you tried the full factory reset from the Youview settings menu.  This is the next option if the Maintenance reset does not resolve.
The factory reset will wipe the hard drive and set this back up in case there is any corruption etc.
Hiltophouse
Will try that. Anyway to backup recordings...?
OCE_Karl
No way currently to back up recordings, but this is the last stage before replacing a box.  In that eventuality, recordings would be lossed anyway.
Hiltophouse
This morning I factory reset the box,deleting recordings from the Boot menu (didn't realise then that your note said from the Youview settings), all worked intially so I left it until tonight, but later tonight I was not able to pause TV.
I then thought I best do it from the Youview Settings, so done that tonight, full reset from YV settings, but within about 30 mins of set up I was unable to pause tv again.
OCE_Karl
OK, next option is to replace the box and see if this helps.
Another box is on the way.
Hiltophouse
Thanks Karl. How do you send replacements, is it Royal Mail? Would you have a tracking number as yet please?
OCE_Karl
We use UK mail and Royal mail.
I'll drop you a PM with the Tracking number.
Hiltophouse
Brilliant, its due this evening.
Thanks for all your help.
OCE_Karl
No Problem 🙂
Glad it's going to arrive promptly.
Hiltophouse
Been using the replacement box over Christmas and had been mostly behaving (the old one had really died)
I've had to hard power reboot a few times due freezes which was a bit disappointing as I was hoping this was a sign of my previous box getting old.
Today however it was freezing on my recording screens and we lost a number of recordings from that screen....we had 2 pages yesterday and now not even 1 page full. Had to hard reboot but still recordings are missing. Software reset and then maintenance keep recordings still didn't bring them back 😞
OCE_Karl
If this has failed, can you try the full factory reset from the youview menu.
Hiltophouse
I've done the full factory reset from the Youview menu on Tuesday, obviously that wouldn't bring back recordings from Christmas.
Why would reset need to be done on a new box only days after receiveing ? are they refurbished boxes?
OCE_Karl
If there was a corrupt recording that was gumming things up, only way to clear and re-set the hard drive fully would be the factory reset.
Now the reset has been done, try a few sample recordings and see if they play back ok.
Hiltophouse
Hi, A further update since the factory reset on my replacement box….. I’ve had 2 more recordings disappear. Also had the box fail to pause tv tonight, it just went to black screen and then to the main channel preview screen that you get at power on.
This one seems problematic as well, are they new or refurbs? Maybe a duff drive....
Please can you arrange a replacement. Many thanks
OCE_Karl
I'll get this swapped out and we can see if it is the box.
Hiltophouse
When you have it please can you send tracking info so I can ensure somebody is in.
Many thanks
OCE_Debbie
Hi Hiltophouse
You should receive the replacement TV box within the next 24hrs.
