TV box is dead
phil1349
Message 3 of 3
My TalkTalk tv box has completely died and is totally unresponsive. I have tried powering down and rebooting but no response. It has been a bit dodgy for a few weeks not responding to the remote, rebooting fixed this until now it is totally dead.
Message 1 of 3
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
fre55die
Message 2 of 3
Hi @phil1349
I have escalated this to OCE support and they will respond on here A.S.A.P.
Please do not add anything on here OR start a new thread until an OCE responds as the system will see this as a new post and move you to the back of the queue.
Unfortunately the response times are extremely delayed and currently can take a couple of days instead of the usual matter of hours. Please bear with us as an OCE will get back to you as quickly as possible.
