TV box keeps freezing
plodder
Message 2 of 2
We have a Huawei DN360T TV box. It has worked fine for years but now it freezes after using it for a while eg on catch-up. Can't operate it from the remote, only switch that works is the power switch on the back.
I have checked our line - no problems and 18MBS reported. Tried a factory reset, which worked, then during setup it froze again. It may be a hardware problem, like overheating, because if you do restart after a freeze it only runs for a shorter time before freezing again.
Can you send out a replacement please?
TC
1 REPLY 1
Message 1 of 2
I'll get the box swapped out for you.
