on 30-05-2022 09:59 PM
I've had no TV service now for several days. My TalkTalk / Youview TV box (Huawei - standard, not a recordable one) has only been displaying one of the three blue LEDs (when switched on, usually all three would flash in sequence for a minute as the box 'warmed up')
The TV display is locked onto Channel 5 with no picture, just the text 'event information is not available' and 'no signal - please check your antenna connection) I can't change channel or call up the Youview services using the handset - the screen doesn't change.
I've checked and re-checked all connections, the Netflix option on my TV is working so I know the broadband signal is working.
I've tried to reboot the TV box by holding down the '+' and '-' buttons when switching it on. No change, apart from now of the three blue LEDs, the one on the left and one on the right remain lit - no flashing, or sequential warm-up phase.
Do these TV boxes wear out/ fail permanently? Do I need a new one, or is there some other reset fix I can try?
on 01-06-2022 12:52 PM
If you start your own thread (new message), we’d love to help.
We’ve found that posting in someone else’s conversation makes it harder to follow when looking for an answer.
It’s easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
on 01-06-2022 12:40 PM
Hi Karl
My TalkTalk box has not been working for about a week. It is not showing any signs of life. I tried the pressing of the plus and minus buttons at the same time to try to reset but there are no lights coming from it whatsoever. I am not sure what to do next?
Caroline
on 01-06-2022 08:36 AM
No Problem 🙂
on 31-05-2022 02:43 PM
Update - TV box now appears to be working! I have no idea what's happened.
I'd left it overnight and have just tried another reset, and checked my TV input channels, and it's operating normally.
Thanks again to Fre55die and Karl for the replies - and no need for a new TV box, Karl
on 31-05-2022 06:30 AM
Hi 5tok3s
I'll get a replacement box to you.
on 31-05-2022 01:09 AM
Can you get into settings ? blue YV/Menu button on remote Up to the cog wheel then factory reset from the menu?
on 31-05-2022 01:01 AM
Thanks Fre55die, but I've tried the reset and now the TV box is completely shut down - no signs of powering up at all (no LEDs) and all the while, the TV displayed the same 'channel 005' blank screen with messages as before. There was nothing to indicate any kind of factory reset, no option appeared on screen, nothing. And now the box seems to be completely kaput.
30-05-2022 11:03 PM - edited 30-05-2022 11:12 PM
Hi @5tok3s
From the + - menu select factory reset and see if that works.
Full instruction s here : https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode/
