TV box upgrade
franatic
Message 2 of 2
would like to upgrade to the tv box plus. How do i do this and how much will it cost?
1 REPLY 1
Gondola
Message 1 of 2
Hi franatic
TalkTalk have ceased to supply a TV Plus STB. You can buy alternative retail versions of the Freeview Plus STB. There are new STB's on the way but none including a Hard Drive to make recordings as the Plus STB did.
GondolaVolunteer 2017-2021
 Like below to appreciate my help . . . Mark as solved + Accept as Solution
