TV internet connection
Shrews
Message 25 of 25
Hi, for the last few weeks I have had a problem connecting to the internet channels on my tv, usually turning everything off waiting a couple of minutes and turning back on solves the problem but it is annoying, also I can be watching a program and it will just turn off.
24 REPLIES 24
Message 1 of 25
If you start your own thread (new message), wed love to help.
Weve found that posting in someone elses conversation makes it harder to follow when looking for an answer.
Its easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
Check your home phone number or account number are also added to your Community Profile as that will really help us to find your details quicker.
Message 2 of 25
Hi, I have an issue with tttv. There is no Internet connection to my tv. I believe the problem is with my powerline adapters. One of them is no longer lighting up. Everything else appears to be working normally, including the router.
Audrey
Message 3 of 25
OK, we have replaced the adapters, lets swap out the router also.
Message 4 of 25
Hi Karl, I celebrated too soon, the last few days I have been getting the not connected to the internet message.
Message 5 of 25
Excellent, glad to have helped.
Message 6 of 25
Hi Karl. I connected the new adapters a week last Saturday, Sunday morning I couldn’t connect to the tv internet channels, I turned everything off and then back on again, since then - 7 days- there has been no problem, so it looks like you have solved the problem, so thank you.
Message 7 of 25
Okay I have done that
Chelsea Trundley
Message 8 of 25
@cstrundley If you start your own topic the support team will be glad to help.
Message 9 of 25
Hi I have the same problem, sometimes the TV works sometimes it doesn't and sometimes the entertainment boost works and sometimes it pixelates. Can you tell me what might be wrong please
Chelsea Trundley
Message 10 of 25
fingers crossed 🙂
Karl,
Message 11 of 25
Okay thanks Karl, let’s hope that solves the problem.
Message 12 of 25
The internet connection looks stable so I've a new set of adapters on the way to you.  The current ones are about 7 years old, so lets get these replaced to make sure they are not the issue.
Message 13 of 25
Hi Karl, I have no internet connection on the tv today.
Message 14 of 25
Excellent.
Message 15 of 25
Hi Karl, the tv internet connection is okay this morning, I will see how it goes over the next week and will let you know.
Message 16 of 25
Check back in tomorrow and I'll see how the line has performed overnight.
Message 17 of 25
Thanks Karl, I will keep my fingers crossed.
Message 18 of 25
I can see some drops on the broadband side, so trying to determine if there is a broadband issue or communication issue with the tv / router.
I've made a change to the router and optimised the line to see how things behave over the next day or two.
Message 19 of 25
When I turned on the tv this morning there was a message saying the tv was not connected to the internet and all the green lights are on both of the adapters.
Message 20 of 25
When you have an issue with the TV channels, look at the adapters and see if all 3 lights are green or if any turn amber / red.
