TV internet connection
Shrews
Message 25 of 25
Hi, for the last few weeks I have had a problem connecting to the internet channels on my tv, usually turning everything off waiting a couple of minutes and turning back on solves the problem but it is annoying, also I can be watching a program and it will just turn off.
24 REPLIES 24
Message 21 of 25
Yes both directly into sockets and the green lights are on.
Message 22 of 25
OK, you are using powerline adapters.   Are the adapters direct into wall sockets ?  Are the lights on and green on the adapters ?
Message 23 of 25
There is definitely no cable from the router to the tv box. I have two pieces of equipment, one plugs into a socket by the router and has a cable to the router and the other into a socket by the tv and has a cable which goes into the tv box.
Message 24 of 25
Is the TV box direct to the router with a cable or are you using powerline adapters.
