TV
warmaj
Message 3 of 3
I want to cancel my TV service as I don't use it.
mandisa1-TT
Message 1 of 3
@fr8ys Thank you so much for the support, we are able to remove and add some boosts:)
@warmaj I have removed the £5.00 TalkTalk TV subscription for you, your monthly charge going forward should be £45.73, it will be fully disconnected from your line in 24 hours, please note as this is an add on it can be added again whenever you require it.
Message 2 of 3
You will need to phone and speak to the loyalty team to get this removed as changes to contract can't be done via the forum.
Try phoning 0345 172 0088 tomorrow.
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
