Talk talk box no signal
Lizziekendall3894
Message 3 of 3
Whilst watching BBC iPlayer my box now turns off and a message comes up on the TV saying no signal. The box then turns itself on and off around 5 times and I cannot continue watching anything. Any ideas?
Message 1 of 3
Hi Lizzie
Did you follow the advice from my colleague, and did this help ?
Message 2 of 3
No idea what's causing it but resets often.
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
Please note that if you are eligible for a new box, TalkTalk now only supply non recordable ones., So it's best to try all alternatives if recording is important to you.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Please post back when done.
Thank you
Hope the above helps.
