Talk talk box problems
4 REPLIES 4
Shaza248
Talk talk box freezes when playing back recordings, failing to record and now not recognising and working off the remote at all. Have done a no:2 reset preserving the recordings and it has got worse.
Shaza248
If you have tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347) then the only thing left to try is a Factory Reset from the settings menu. You will lose your recordings, but as TalkTalk no longer provide recordable boxes in exchange, if you are eligible for a replacement, it is the only way you will be able to record going forward if the reset does repair the hard drive, which has become corrupted.
Let us know how you get on, as you are in the staff's queue for a response.
Shaza248
Done a complete reset, wiped out all recording  (which was only 30% of hard drive)
Has done some recording. Watching a recording and it's not responding to the remote. New batteries in remote still not responding. Can't stop the play back or fast forward.
This can't be right as never used to do this.
Shaza248
OCE_Karl
does the remote work as normal for all other functions ?
Shaza248
The only button that works is the power button on the remote and when turned off and back on you return to what was on when it stopped working.
The only way to reset the box is to turn top set box off at button at the back. Happening more frequently now probably every other day
Shaza248
