Talk talk youview box is very hot and not working properly
Gerbs
Message 2 of 2
my talk talk youview box is very hot and not working properly
1 REPLY 1
fre55die
Message 1 of 2
Hi @Gerbs
What exactly is the problem with the box? You have checked that the air vents on the top, Side and bottom are not clogged with dust etc. and have a free flow of air with nothing on top of the box and space to the side of it ?
VERY IMPORTANT FOR SUPPORT !!!!!!
