TalkTalk TV Box System Start Up Error
stevieg77
Message 6 of 6
I have been unable to start my Huawei DN370T box for a week now with a System Start Up Error every time I start up and have tried all the reset options. Every time I have spoke to technical support they have said that it is due to a connection problem in my area which engineers are looking into. I have had no problem with Broadband with the Internet, Netflix etc working fine.
They are adamant that the issue is not related to the box but I cannot understand why this is happening and appears to be no indication when this connection issue will be fixed.
I am trying to comprehend how this is not related to a problem with the TV Box so any assistance much appreciated.
Many thanks in advance.
5 REPLIES 5
Message 1 of 6
No Problem 🙂
Message 2 of 6
New box has arrived and everything up and running again.
Many thanks for your help both.
Steve
Message 3 of 6
I'll get a replacement box out to you.
Message 4 of 6
Many thanks for your quick response. I have had another go at running the maintenance resets in the link but still no luck.
Have updated personal details so hopefully can get resolved next week.
Message 5 of 6
I'm sure you are being spun a line here, but unfortunately it will probably be Monday before staff here can help you.
One thing you can try is a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
You will then need to reset your personal settings (such as parental controls / RF loop through / Surround Sound etc.) and also reset your scheduled recordings if it works.
Please let us know how this goes and you are in the staff's queue For a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
If you are unsure of your phone number, you can find this in My Account or dial 17070 from your land line phone and this will confirm the number for you.
Thank you
