TalkTalk Tv Box
OHamit
Message 4 of 4
Recently I have been having a problem with my Youview box these past few days it is stuck on waking up I believe it may be a technical fault in the box since the box makes a slight clicking noise when I am near it I can hear the click. When I turn the box on it is stuck on the waking up page for hours trying to load. I have tried restarting the box from the back of the box as well as the mains plug. I have also tried resetting the box using the - + function and holding it down once the box was restarted to try and reset it as stated online when I searched for problems with you view box however none of what I did worked therefore I believe it is a fault with the actual interior of the box itself.
Can I get a replacement box sent to me to replace the one I currently have for a new one? any help is much appreciated thank you.
Kind Regards,
Mr O.Hamit
3 REPLIES 3
Message 1 of 4
You're Welcome.
OHamit
Message 2 of 4
Thank you very much for your help Karl will await for the replacement box.
Message 3 of 4
Hi OHamit
A replacement TV Box is on the way to you.
This should arrive within the next 48hrs.
