on 11-12-2021 04:44 PM
My Talk Talk YouView TV PLUS Settop Box has for some time not been functioning properly. When watching programmes via the apps, the box repeatedly randomly switches to "live" television. Recordings are often truncated/not recorded. The box is also very slow. Please assist.
on 02-03-2022 02:59 PM
it's on the way.
on 02-03-2022 02:50 PM
Hi Karl ---
Yes, please, send a non-recording Talk Talk TV box.
Many thanks in advance,
Advia
on 11-01-2022 11:11 AM
i can send a TV box to you. This will not be a recording box as TalkTalk have not provided these for just over a year now. Would you like me to send this ?
on 11-01-2022 10:46 AM
Hello Karl
We have tried all of the above, without success. The faults still remain. Please advise.
Best regards.
on 13-12-2021 09:29 AM
Hi Adiva
Try the reset option as advised and let me know if this helps.
on 11-12-2021 08:08 PM
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
Please note that if you are eligible for a new box, TalkTalk now only supply non recordable ones., So it's best to try all alternatives if recording is important to you.
Hope it works but if not then please let us know and I’ll flag for further assistance.
