TalkTalk YouView box faulty
Bluebird1927
Message 4 of 4
Hello
I've had my TalkTalk YouView box (Huawei DN372T) since I first joined TT 5 years ago.  A few months ago, it started freezing and crashing, but the problem is now beginning to escalate into almost a daily occurrence - this either occurs when trying to access one of the Apps/Players or in some cases simply at random.  The only way to bring life back into the box is by pulling the plug out on the back and going through the full restart.
All the software is up to date and no problems with broadband etc.
Any ideas how I can fix this?
3 REPLIES 3
Message 1 of 4
Have you tried any of the resets as mentioned by fr8ys ?
Message 2 of 4
Oh and you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
Message 3 of 4
Have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
