TalkTalk box lost sound ,Distorted picture
Janegold
Message 3 of 3
2 on line chats with Tecnical advisers have been disconnected / they just went., this morning. One was with sphelele the other a lady. They were trying to sort this out.
talk talk box Huawei model DN372T. Had this box for quiet a few years. Last night changed channel. Lost sound and picture became distorted. Rebooted box. All good. Then changed channel same happened again. Checked connects. Tv working ok. Internet connection all good.
It’s still happening this morning.
Could it be the TalkTalk box has come to the end of its life. ?
how do I get another one. ? Christmas is coming.
Thankyou for reading g this.
Yellow Labrador s are the best .
Janegold
Message 1 of 3
Thankyou. I’ll try this when get home.
Message 2 of 3
have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the support staff look at other alternatives.
Please note that if you are eligible for a new box, TalkTalk now only supply non recordable ones., So it's best to try all alternatives if recording is important to you.
Hope it works but if not then please let us know and I’ll flag for further assistance.
