TalkTalk controller
Brittainb
Message 2 of 2
Trying to pair controller to new JVC TV.  I can turn TV off with TalkTalk controller but unable to turn on again.  Have to use TV controller to do this.  I have tried all suggested codes.
Any ideas?
1 REPLY 1
Message 1 of 2
We do try to keep our help site up to date with as many manufacturer codes as possible, and newer codes are added as they are provided from the various manufacturers.
Unfortunately, some models are not listed, and until such times as the manufacturer provides these codes, the help we can offer is limited.
You can try searching for a generic code that may work, and more advice may be found within our Online Help Article.
