TalkTalk tv box internet
Lianne13
Message 12 of 12
I’ve upgraded my router and now my internet on my TalkTalk tv box won’t connect.
Please help. I’m paying for a service and can’t use it!
11 REPLIES 11
Message 1 of 12
Should arrive tomorrow.
Message 2 of 12
Can you let me know what day it’ll arrive so I can make sure I’m in?
Message 3 of 12
A replacement set is on the way.
Message 4 of 12
Yes I have a first adapter. It doesn’t look like the one in the picture.
can you send replacements please?
Message 5 of 12
I'm unable to see anything connected to the router via the ethernet cable, Do you have the first adapter connected to the router with a cable.
If so, the adapters could be failing and may need replacing.
The setup should look like this :
Message 6 of 12
Have done that but it still won’t connect. Can I have an engineer out to fix the problem please?
Message 7 of 12
Are the lights green on both adapters ?  Are they direct into wall sockets ?
Have you tried resetting the adapters then re-pair them ?
There is a reset hole on each adapter and you can usually hold a pin in this for 3 seconds to fully reset.
Message 8 of 12
I use a powerline adapter. It’s on green but still won’t connect.
Message 9 of 12
Your internet connection looks fine.  How is the TV box connected to the router /  Is it direct with an ethernet cable or do you use powerline adapters ?
Message 10 of 12
I’ve updated my phone number now.
Message 11 of 12
Can you please add your home phone number or Account number to your Community Profile so I can locate your details.
If unsure of your phone number, simply dial 17070 from your land line phone and this will confirm the number for you.
