Talktalk TV box
michael1942
Message 2 of 2
If I plug the TV aerial direct into my TV the signal strength and quality is 100%. If I plug the aerial into the TV box, then take a cable from the antenna out socket on the rear of the TV box and connect it to my TV the signal strength drops to 36%. Is the TV box faulty and need replacing.
1 REPLY 1
Message 1 of 2
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
