on 22-03-2022 07:31 PM
Hi, I hope that someone can help.
My talk talk TVBox was recently delivered and I am trying to set it up. Unfortunately, once it connects to the router it then will not connect to the internet. Either via automatic option or if i add in the manual IP Address subnet mask default gateway primary and secondary ~DNS information. My internet works fine as my router connects to my PC and other devices, so its not a router issue. All the wires are connected properly and i have turned everything on and off again about 20 times now.
What do i do?
on 23-03-2022 07:58 AM
Hi Chris150
Is the TV box connected directly to the router or are you using powerline adapters?
