Talktalk tv box missing apps
VitiLevu1
Message 3 of 3
Missing Ondemand Apps
Why can’t I find ITV HUB and C4 to name but two in the App section of my new talktalk tv box?
The box was updated at the time of installation which was over a week ago.
Surely ITV HUB and C4 should be accessible?
Message 1 of 3
Hi VitiLevu1
If you can answer the questions from fre55die, this will help us diagnose the issue.
Also, have you tried a Youview Maintenance Reset
fre55die
Message 2 of 3
Hi @VitiLevu1
How is the router connected to your box? Is it direct via a cable or via Power Line Adapters? If via PLA's are BOTH plugs showing 3 green lights?
These apps need both a good aerial signal connection and a solid internet connection to function.
