Talktalk youview box
Lynne01
Message 4 of 4
As of past week we are getting failed to record on a number of channels, also previous recordings on the youview box will no longer play, we just get a black screen, any ideas as to why this has happened?
Also did a router health check and it said unable to identify the router you have connected or its software version (this is a router sent by Talktalk) Any ideas please?
3 REPLIES 3
Message 1 of 4
There may have been a corrupt file on the drive, but see how it goes now the drive has been cleared.
Lynne01
Message 2 of 4
Thanks for the advice, I tried the soft reset but it didn't resolve the problem. I had to do the full factory reset which so far seems to have done the job, just a shame we had to loose the recordings (kids weren't happy).
Lynne.
Message 3 of 4
Try a Youview Maintenance Reset  and see if this helps with the recording issues.
If they still fail after this, then the only option is to perform a full factory reset from the settings menu.
This will erase all current recordings and any corrupt files that could be causing this.
