Transferring recordings
Oneeasygeezer
Message 4 of 4
Is there anyway of transferring existing recodings on the YouView box prior to doing a factory reset?
PB Frewer
3 REPLIES 3
Message 1 of 4
No, the USB option only relates to engineers who can install from there, it does not provide any outward connection. You can use it to power an external USB device though!
Message 2 of 4
Thanks for that although I notice that option 4) is" Internet / USB recovery, keep recordings" doesn't that mean I can backup / copy the files to my NAS or memory stick?
PB Frewer
Message 3 of 4
I'm afraid not. But there are options which you can try which will not affect your recordings: https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode
