Tv boosts
mark501
Message 17 of 17
Cant get tv boosts to show just get black screen
Ive tried resetting router and you view box ive even done maintenance resets tried everything with no luck at all help please
All best mark
Mas
16 REPLIES 16
Message 1 of 17
So sorry I just did start my own thread.
K steel
Message 2 of 17
Hi Motherofgirls
If you start your own thread (new message), wed love to help.
Weve found that posting in someone elses conversation makes it harder to follow when looking for an answer.
Its easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
Motherofgirls
Message 3 of 17
I have been paying for the Entertainment TV boost but the channels are not working in our TV guide. Even selecting channel 301 manually does not work, it just displays that I need to set up which I’ve tried but says I’m not allowed to change the boosts.
I have called talk talk helpline on four occasions. The duration of all calls were nearly 2 hours and there was no resolution to the problem. The advisor concluded that we needed to pay £65.00 for an engineer but I am  quite relucant to do so as this problem is no fault of ours.
Could you advise to how we can resolve this problem. Also, how we can get a refund on the entertainment boost as we have been paying for the channels for and not able to watch them.
Many Thanks.
K steel
Message 4 of 17
Hi Mark
Glad to help.  Any issues with any services, always ask the community first, and we'll do our best to help.
Message 5 of 17
Its all fixed working perfect cant thank you enough if it wasn't for you I think I would have been in the same boat for a while
All the best mark
Mas
Message 6 of 17
No Problem 🙂
Message 7 of 17
Thanks karl all the best
Mark
Mas
Message 8 of 17
This is logged out to BT Openreach for a Non Appointed engineer - Non appointed means the engineer will be dispatched to look at the line without requiring an appointment be made with you to visit your property.
Message 9 of 17
Have you any idea how long it will take for them to deal with the problem as its been a while and ive had the crackling since I joined tried to solve it on the phone they just said maybe its your phone or some other excuse , they could checked same as you did problem solved
Thanks mark
Mas
Message 10 of 17
If all devices are 5ghz compatible you can disable the 2ghz if you wish. it would not cause any harm.
Message 11 of 17
No Problem 🙂
Message 12 of 17
Thanks karl for you time I appreciate it
Mas
Message 13 of 17
Still seeing an issue.  I've raised this over to networks for a possible engineer,
Message 14 of 17
Ive also plugged filter ect into phone test socket its ready to test
Thanks mark.
Mas
Message 15 of 17
No ive got heavy crackling on phone line
Mas
Message 16 of 17
Hi Mark
It's not actually a TV fault you have....thats the good news.... now for the bad news...... looks like you have a broadband issue.
Tests on your line are picking up a possible copper line fault.
I'm only showing your line in sync at 2mb, so way below the speeds it should be, and certainly not fast enough for TV boosts.
can you check the home phone for me and make sure you have a dial tone on the line with no noise or crackling.
Also, if the main phone socket has a Test Socket  connect the router and filter into this so we can run a fresh test and see if it still picks up the same fault.
